moparmansfield
- Portland
I have a 91 mj with a 94 xj motor. I put a new oil pan on with the blue one piece felpro oil pan gasket. The rear main part of the gasket does not fit well at all. It seems like it is 1/2 inch to long and causes problems. I had to redo the gasket due a leak in the front part of it and found the rear section had ripped. Any ideas? And I did not over tighten the bolts.
