Chark said:
Well my Rusty's extreme...mil wrap springs are starting to sag like a Granny's tits.....what I need is something that will let me still fit my 38's and last. I got a couple years out of my rears now...6.5" with a 1" block. Later.
Just keep what you have and add another leaf. The leaf can be from anything, just pick (or cut) a length that splits the distance between two other leaves. No need to start over again, or spend a bunch of money.
When we bend our springs backwards as much as we do, and flex them as much as we do, we are at risk of them sagging after awhile. Adding another leaf can put them right back to what they were in the beginning.
My old leaf pack was some of the original Tomken leaves from the first lift, all four of the stock leaves, plus a YJ leaf or two. I added leaves I think three times over 8 years, and the springs always worked like a champ. I had a problem with it sagging on the right side, so I added another leaf to that side only......twice. I ended up with 8 leaves on the left side and 10 leaves on the right side, but the lift was even and the ride and flex were balanced. I like using factory leaves rather than aftermarket leaves because most of the time they are a better quality steel.
Leaf springs aren't rocket science, play around with them a little. You have a mil wrap second leaf, so you have a good foundation. Stick with the pads on the ends of each leaf, as friction can be bad for leaf springs causing a stiffer ride. Better to have another leaf to give it strength with little friction than less leaves with a lot of friction. While you have the springs apart, clean them up and repaint them. You can also add a couple of leaves and then use full length liners rather than just the pads on the ends, which works very well to reduce friction. You can also add a pad to the middle of the leaf, and then the end pads, which keeps the springs seperated and reduces friction. You can get good weight carrying capacity, lots of flex, and a great ride out of a thick leaf pack if you take steps to reduce the friction.
More than you asked, but..........
