What I used starting at the upper bolt; A swivel socket filled with axle grease to hold the bolt, a 3 inch extension, an 8 inch 'wobble end' extension, enough LONG extensions to reach in from behind the transfer case, ratchet, finally, good hand cleaner to clean the oil of your arms.
