Battery Hold Down bracket
Lowrange2
Abbeville, SC
Since I've always ridden around with my battery flopping around in the engine bay I need to strap it down in place...
Does anyone have a spare OEM battery hold down bracket with the hooks and wing nuts? My tray is all intact I just need to the two posts, nuts and bracket across the top of the battery.
Advance sells a OE-style universal hold-down kit IIRC. Either that or some all-thread, nuts and some metal strapping should do it.
If you want OEM I can check with my local Jeep yard.
I used a generic one cut to fit for a long time. You have to cut one of the tabs to fit around the core support.
The only ones I see at the parts store are no where near the correct size. I'll probably just make one out some flat stock I have laying around.
