Battery, alternator, voltage regulator?
ScottPriestley
San Antonio
I've got a problem with my 01 Cherokee. Last night I drove to a restaurant, shut it off for about 10mins, started back up fine, drove to gas station and turned it off. When I came back after 5 minutes it was dead. Got a jump and drove it home but got a Check Gauges light and the Voltage gauge pegged to 16V while driving. When I idled in the driveway it returned to normal. Drove around the block and the gauge did the same and returned to normal when parked and idling. Most likely battery is fried but that behavior does sound like the vintage regulator, right?
PCM failure is very rare. With diagnostics, you should always start with the basics, inspection and testing.
If the dashboard gauge shows 16 volts typically there is connection or wiring issue. If the dashboard gauge shows 9 volts, typically there an alternator issue.
Suspect
• dirty, corroded, damaged, or loose battery terminal or wire connections
• internally corroded battery wires
Perform routine maintenance of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator. Look for corroded or damaged cables or connectors and replace as needed. Copper wires should be copper color, not black or green. Battery terminals and battery wire connectors should bright silver, not dull gray/black and corroded. Do the same for the grounding wires from the starter to engine block, the ground wires at the coil, and the ground wires from the battery and engine to the Jeep's frame/body. You must remove, wire brush, and clean until shiny the cable/wire ends and whatever they bolt onto.
Jeeps do not tolerate low voltage, bad wire connections, or poor grounds.
Place your DVOM (Digital Volt Ohm Multi-Meter) on the 20 volt scale. First check battery voltage by placing your multi-meter's positive lead on the battery's positive post ( the actual post, not the clamp ) and the negative lead on the negative post. You need a minimum of 12 volts to continue testing. Next, leave your meter connected and take a reading while the engine is cranking. Record this voltage reading. Now connect your positive lead to the battery terminal stud on the starter and the negative lead to the starter housing. Again, crank the engine and record the voltage reading. If the voltage reading at the starter is not within 1 volt of battery voltage then you have excessive voltage drop in the starter circuit.
Typical voltage drop maximums:
• starter circuit (including starter solenoid) = 0.60 volt
• battery post to battery terminal end = zero volts
• battery main cable (measured end to end) 0.20 volt
• starter solenoid = 0.20 volt
• battery negative post to alternator metal frame = 0.20 volt
• negative main cable to engine block = 0.20 volt
• negative battery post to starter metal frame = 0.30
• battery positive post to alternator b+stud = 0.5 volt with maximum charging load applied (all accessories turned on)
