CaliXJ
- Oceanside, CA
91 H.O., AW4, 5.5" lift, 33x12.50x15, 4:56 gears, blah,blah,blah
Ok so i installed the Banks Revolver header on my heep and after tightning the belt up, afew days later the water pump bearing starting making noise. Replaced it! That one leaked! Replaced again and did upper and lower coolant hoses too. Drove for a few weeks but could never get the jeep to run just below the 210 mark like it used to at highway speeds. Temp started going higher in traffic and back down at speeds. (still above 210 but NEVER to the next line)
Get home friday and coolant started shooting out of a freeze plug and noticed another was leaking a little to. (NEVER over heated) Thought OK "air in the system" Tear the intake and exhaust back off and replaced all 5 on DS of the block with brass plugs, and new 195 superstat. Thought this has got to do it!. Well not exactly. Still can't get it below the 210 always just a hair above.
Back to the Banks header. When installing it i had to move the cross over pipe atleast 1" closer to the block/oil pan than the stock one. Could this be where the added heat is coming from? Or should i be looking other places?
I do have the ZJ fan clutch upgrade (still seams tight) and the stock electric fan does work at keeping temps from creaping above 216. I can get the temps below 210 with heater running so i know heater core is good. Could this be a clogging radiator? Or just the added heat from the header being closer to the motor?
Oh and i have a trans cooler in front of mechanical fan bypassing the radiator. Has been this way for a yr though with no cooling issues.
If a MOD thinks this is OEM please move. I placed here because maybe mod related?
