gird123
- minden, nv
I did some searching and I have been unable to find the answer.
My dad is running 35x15x8s with about 6 to 6.5 inches of lift on his 1989 xj. When turning the tires rub the quick disconnect on the stab. He would like to change the back spacing currently 4"s and he is trying to decide between 3" and 2.5". Does 2.5" interfere with the brakes? Advice appreciated.
Pros:
more stable
Less rubbing
Cons:
Use more unit bearings.
http://www.naxja.org/forum/showthread.php?t=1057214
Thank you,
Nate
Pros:
more stable
Less rubbing
Cons:
Thank you,
Nate
