XJWiki
- Rhode Island
Bought these axles a year ago and never got around to installing them.
$1100.00 obo Location: RI
rear axle:
brakes: everything is from a ZJ (93-98 grand cherokee)
locker: powertrax no-slip
cover: riddler
29 spline axle shafts (stock)
front axle:
disconnect housing converted to non disco
detroit tru-trac
ball joints: WJ lowers, XJ uppers
knuckles: WJ with jks flanges and go-fer-it flip inserts
tie rod ends: 24 mm from a WJ
if you need a new one, contact crown in canton, ma.
steering links and jam nuts are from JKS
unit bearings: 2001 xj. you have to grind down the flange to fit into the rotor
rotors: 2wd ford explorer sport track with a large grade 8 washer behind it. it's about .090" thick if i recall...
shafts: 297x
track bar mount: 1.6" wide. you'll probably want to use the upper hole
rear axle:
cover: riddler
front axle:
detroit tru-trac
shafts: 297x
