Axles, suspension parts, JKS, OME, more in Tucson, AZ
Chill-X
Tucson, AZ
[SIZE=+2]New/Open Box[/SIZE] (all parts/hardware/instructions/open box included unless noted):
[SIZE=+1]Shocks & Accessories:[/SIZE]
[SIZE=+1]Other New Parts:[/SIZE]
[SIZE=+2]Used tools:[/SIZE]
[SIZE=+2]Used Jeep parts/pulls:[/SIZE]
[SIZE=+1]Stuff that isn't axle or suspension[/SIZE] (all of this pulled from my '99 XJ Sport 4 door with about 70,000 miles):
  • Bumpers:
    - Front Bumper side plastic pieces - faded, one side has crease in the plastic from being hit
    - Front Bumper mounting brackets - should have bolts as well
    - Front Bumper license plate plastic mount
    - Front Bumper lower plastic deflector
    - Rear Bumper mounting brackets - probably have bolts as well
    - Rear Bumper to body/tailgate plastic piece
    - Front & Rear metal bumpers Desert Sand Pearl Coat - both have been bent/bumped/smacked around
    Looking for $60 for all the bumper stuff. I may also be willing to part with the rear bumper endcaps/lower quarter guards (whole), and possibly all 4 fender flares (for more $$)
  • Spare tire mounting hardware & floor bracket (behind rear seat) including hand-tighten lug nut thing - $5 local, can ship
  • Emergency bottle jack/handle/lug nut tool - $10 local, could ship
  • Wheels: Qty. 4 - 15x7" aluminum wheels - 5 wide spoke design, color matched to body (Desert Sand Pearl Coat), has center caps, includes worn-out 225/75R15 tires - $100 local, could possibly remove tires to ship?
  • Transmission Crossmember - no built-in drop, in good shape (not dented) - $10 local, could ship
  • Rearmost exhaust pipe hanger - does not include clamp - may be bent a bit but useable - $free
[SIZE=+1]'87 XJ (guestimate on year) Dana 44 Items:[/SIZE]
  • Dana 44 axle shafts - 30 spline, 5 on 4.5" bolt pattern, drum brake length studs, stock shafts with one shaft 0.5" longer than the other - no bearings/retaining plates included - buy these and prep so you have spares! $90 shipped
  • Dana 44 drum brakes - big brakes includes e-brake cables - these use 10" diameter x 2.5" wide shoes (as opposed to the 9" dia x 2" wide in the Chrysler 8.25" axle) - these will need to be cleaned & rapaired - new cylinder, possibly new shoes, resurface drum (I understand that these could be put on other axles for a brake upgrade), will include Dana 44 drum brake hardlines - $40 local pickup/delivery, can ship but they're freaking heavy
  • Dana 44 stock (thin) cover - has hole drilled by junkyard which was welded closed - $free
[SIZE=+1]'99 XJ Rear suspension/axle pull:[/SIZE]
  • Chrysler 8.25" 29 spline axle working pull, 3.55 gears, open diff, standard cover, drum barkes: 9" dia x 2" wide drum shoes (see Dana 44 info above) with brake hardlines and e-brake cables (including cable brackets)
    - stock leaf springs still mounted (includes axle u-bolts and plates, but does not include leaf spring to frame or shackle bolts)
    - Brake drums, leaf springs rusty but probably still useable / may be resurfaced?
    - Axle tube & mounts have surface rust
    - Stock shackles (no bolts)
    - Stock skinny anti-swaybar - has axle-end hardware but missing frame-side mounting brackets/bushings
    - Have stock shocks (need replacing) if you want??
    - '99 4.0L/AW4/NP231/C8.25" stock rear driveshaft - has scaly-rust on tube - $free
    Will sell leaf springs/swaybar/driveshaft seperately or with axle
    Axle - I will pull off leaf springs if you don't want them. I will not pull off the drum brakes because I don't want to pull the c-clips to get the backing plates off.
    Hoping to get $220 axle, $250 for everything from my rear-end pull
[SIZE=+1]'99 XJ Front Suspension/axle/steering pull:[/SIZE]
  • Dana 30 working pull, 3.55 gears, open diff, standard cover, disc brakes (includes stock rubber brake lines)
    fairly clean/relatively rust free (much better than C8.25") except brake calipers and rotors
    - Upper and lower control arms including stock nuts and bolts at both ends, also includes LCA adjusters
    - Coil springs good shape including lower retainer clip & bolt in spring perch
    - Coil spring rubber isolators (upper) & bumpstops
    - Swaybar end-links - includes hardware except it is missing 2 of 4 upper-end washers (swaybar not included)
    Hoping to get $270 axle & brakes, $300 for axle, brakes, UCA & LCA, springs, swaybar end-links
  • Trackbar including bracket (very good shape) - does not include axle-end or frame-end nuts or bolts - $55 shipped
  • Stock steering linkage (all pieces of linkage are there but probably needs new boots and reassembly) including stabilizer with axle-end nut/bolt - $50 shipped
  • Steering Box (used, may have a shaft seal leak) working when pulled, includes stock XJ Pitman arm
    - Aluminum steering box spacer (intact)
    - have stock bolts for steering box as well
    $70 shipped, add $5 for spacer if you want it
[SIZE=+2]Information:[/SIZE]
[SIZE=+1]Pricing/Shipping:[/SIZE]
Prices are negotiable, however I am trying to get as much as I can. Currently, I have been unemployed for several months and an running a bit short in funds for July. Consequently, I will be able to ship out very quickly unless I manage to get an interview somewhere or start a job (I am an Accountant with 3 years experience and excellent academic credentials). Shipping will be via FedEx Ground, UPS Ground, or US Mail.
[SIZE=+1]Axle shipping:[/SIZE]
I actually have a large (extra-long) pallet that I can strap one or two axles onto (suspension pieces may be unbolted and tied/boxed separately if purchased with axle). So yes, I can ship an axle or both to someone. Freight would be pick-up by trucker in driveway.
[SIZE=+1]Local Pickup/Delivery:[/SIZE]
Everything is available for local pickup (near Broadway & Kolb in Tucson, AZ) including if you want to look-at first. I will also be able to bring anything smaller than an axle to you in the Tucson area. I have no way to transport the axles on my own so those are pick-up or ship on a pallet only. I'll knock a few $$ off shipped prices if you pick up.
[SIZE=+1]Payment:[/SIZE]
Money Order or cash is always nice. I will also take PayPal (including credit cards) for shipping or local pickup.
[SIZE=+1]References:[/SIZE]
I was a big computer nut (still am a bit). I have bought & sold many computer parts on forums in the past as Chill-X and have a Heatware Account. I also have 124 verified buyers in PayPal and have been a verified member for in excess of 8 years. This is the first time for me selling Jeep parts though. Naxja.org membership - I have paid for my membership as of 7/3/08 but something went wrong in the automatic system - waiting to get paid member status on forums.
[SIZE=+1]Contact:[/SIZE]
If you want to buy, make an offer, ask questions or anything else, contact me by Private Message or email (this is the same as my PayPal email): jcdickey @ gmail .com - also feel free to post in the thread with questions if you want for the benefit of all. Thanks, Jason
[SIZE=+1]Stuff I want:[/SIZE]
0.75" or 1.25" aluminum spacers from the JKS Adjustable bumpstop system (have leftovers?)
Note to mods: Yes, I have two active for sale threads running with some of the same items in them (National and local). I was under the impression that I would be able to come back and edit my Arizona posting to only have the stuff I was willing to sell local.:(
My mistake, oops.
Hi all,
I've broken the 4th metacarpal in my right hand and I'm right handed so I will not be doing any wrenching :gonnablow
However, with the assistance of my parents (all this stuff and the Jeep are at their place anyway) I will still be selling and shipping.
Sold:
RE Stainless Front brake lines
Pending:
Dana 44 shafts (2 people)
Interest expressed:
Chry 8.25"
MORE SB Brace
Rear Exhaust Hangar
I'm interested in the five spoke rims, I'll probably be coming through tucson the weekend of august 23/24th (I think those are correct) to help my friend move into her apartment, I would appreciate pictures if that's possible.
Here's a picture of the rims.
This is also the color of any other body-painted item up for sale.
Jason
