chris420
- California
I have a 6 inch lift and need to adjust the lower and upper arms as they are out of whack. What is the best way to center the front axle left to right and front to back? It looks like my axle is to far forward and the pinion is pointing down to much. I will be replacing hiems and Johnny joints with Metal Cloak bushings and replacing the factory bushings on the axle were the upper arms connect. My lift is a long arm 6 inch.
