Supermanxj
- Fairfield, PA/DEE-EFF-DUB
I did search...
95 Cherokee sport
4.0 Ax15/231
3 in lift.
Yesterday on my way home from work i pull out of work to get on the highway and as i try to shift into 2nd gear at about 2500 rpm. As i try to push in the clutch...nothing.it will not even budge.
so i try to lower rpms... still nothing.
So i pulled over and it finally compressed.
Since then this has happened a couple of times at different gears
I did check fluid.... still good
any ideas??
JOsh
95 Cherokee sport
4.0 Ax15/231
3 in lift.
any ideas??
JOsh
