jeepster96
- Port townsend,WA
my TC wont lockup and overdrive wont work. sometimes will hunt for it but 90% of the time it just stays in 4th gear. anyone know what the prob could be. its just killing my gas milage:hang:
DaffyXJ said:Let me guess, tires at 31 inches or bigger and stock (3.55) gears?
DirtyMJ said:Does that cause problems or something?
:laugh: i can't imagine the people who run 35's on emDaffyXJ said:Yeah, The larger diameter tire is rolling a farther distance for each turn of the transmission. The VSS & output shaft sensor report that the tranmission is working harder and down shifts to third. What ends up happenening is the TCU and ECU keep the transmission hunting for gears. It will drop into and out of overdrive with the slightest change in grade of the road.
DirtyMJ said:On HO engines? My renix sure as hell doesn't do that - and I am running 31s with 3.55s.
