Oatmeal
- Cedar City, UT
Posted this in OEM tech and only got one response (not very helpful)......have always gotten better results from you guys so......
Have a 96 with an AW4 33s and 4.88s
Have 270K on it but trans has always been serviced regularly, never over heated (have a healthy trams cooler).....throttle valve cable properly adjusted.
Recently it's been shifting kinda soft and dragging out shifts at times.
I know certain engine sensors effect shift firmness.
TPS, MAP, intake temp?
Being that these are the original sensors, am I headed in the right direction?
I know the trans is fine, last fluid/filter change revealed absolutely no debris in pan.
Hans
Hans
