AW4 puzzled
MidNightRydr
North Carolina
Ok so here is the thing I just bought a 91 cherokee from a friend with some issues one of them is the transmission he replaced the valve body now it will not go in reverse some times it feels like it is in 2nd instead of 1st what is you guys thoughts
Thoughts?
Your "friend" doesn't know much about transmission repair, and your english punctuation skills are nonexistant. Find a competant mechanic or a Jeep dealership to repair your vehicle.
First of all, I was simply asking a question. I was unaware that I was in an English class. Second, I guess I was wrong in thinking that I had joined a group of intelligent adults that could speak knowledgeably about jeeps, restoration, and repair. I never laid claim that my friend was a transmission specialist. However, if you did not know the answer to my question, you should have continued to scroll... not be a dick.
Thanks for the help... or lack of, in your case.
Troubleshooting a valve body install over the internet is a long shot. You would be time and money ahead to find a $150 used tranny and swap it in.
By the way, using poor grammar and spelling is viewed by many as simply being lazy and/or disrespectful. If you don't care enough to ask it correctly, why should someone care enough to answer?
You incorrectly capitalized grammar. :gag::rolleyes:
Ok ... I wanted to give an update. I went to tinker on the jeep, an I have reverse again. It seems to be going in and out. I'm not doing anything to make it go one way or another. Suggestions??
Have you tried adjusting he shift linkage? And are he solenoids knows good? Also, is the valve body a known good?
