hi,
i have a 1994 xj with a ax-15 in it and i'm in the process of swapping a vw tdi engine in it.
i'm currently drawing up the adapter plate for it and i ran in a rather big problem.
i can't find anything regarding the bellhousing bot pattern.
i've found bellhousing to trans pattern not good
i've read everywhere that the bell housing pattern to the engine is an amc v8 pattern found that but from looking at the drawing vs picture of the bellhousing it doesn't look the same at all
so does anyone have access to a bellhousing and measuring equipment or have a copy pdf or cad of the engine to trans bolt pattern
thank you
p.s. i will post progress of my work when i do the swap this spring
thank you
