godplayer
- Fredericton, NB
About a month ago I had no 4th gear/overdrive but it returned when i shut off and restarted the Jeep. Well today I lost 4th again but it hasn't come back. No engine light. What the heck??
godplayer said:I replaced that just before x-mas.
Whenever you touch the brakes it'll unlock the torque converter so even though you're in 4th, maybe you think its in 3rd because its not what you're used to. I rarely see 4th gear unlocked. I just had this problem the other day and it went away over time. I still have to tweak my NSS to get it working perfect but its tough in the cold...godplayer said:How can the brake light switch cause the problem? How do I check that? My brake light switch makes a clicking noise when i push the brake....it always has since i bought the Jeep.
godplayer said:How much rpm variation with there be from unlocked to locked torque converter?
lawsoncl said:I'm not sure on the newer XJs, but on the older Renix ones the brake switch for the TCU is seperate fro the brake light switch. It's white and higer up on the brake pedal. If you have cruise, it also has a vacumn line going into it.
godplayer said:I just disconnected the TCM and tried shifting manually. It appears that with the TCM disconnected I get 4th/OD back.
