1990 Wagoneer Limited- I have found that my shifter is a little wonky and would like some input. Park, Reverse, Neutral, Drive and 3 all work as they should with the exception that the red indicator is off by one position as soon as I come out of Park. I can push the lever up and the indicator is then correct. My issue is that I cannot shift into 1-2. The shifter only drops down to 3. Is there an adjustment for this? Everything that I read is for adjusting the linkage for proper Park positioning and starting ability. Any feedback on this?
