gimike812
- Tucson, AZ
I tried to install my aussie locker in my 8.8 and now have a problem. The problem being I pulled it all apart all internals look great minimal wear. Doing the cross pin to gear spacer tallerance check and the install paper work says I need a minimum of .006-maximum .020. Well with my .030 thrust washers in like the instructions say I have .002 to .001. I went and got new thrust washers the same story. Call a diff. shop and they say the minimum thickness for 8.8 thrust washers is .030. They only get thicker from there. I understand things can be worn and having to much gap but I dont have enough?
What should I do machine my thrust washers thinner to get my needed gap or just install it and run it.
