ARB dual compressors at Just Differentials!
Just Differentials
Differentials and Axles!
Washington State
ARB Air Locker
Twin Onboard Air Compressor
CONTACT [email protected]
CKMTA12
This compact vehicle mounted compressor has been designed to do everything! Activate your ARB Air Locking Differentials, air up a 35" tire in less than a minute and run air tools. This 100% duty cycle, 6.16 cfm compressor is built to support all of your compressed air needs.
Voltage: 12 Volts
Current Draw No Load: 28 Amps
Current Draw Under Load: 50 Amps
Air Flow No Load: 6.16 CFM
Air Flow Under Load: 4.65 CFM
Weight: 20 Lbs
Duty Cycle: 100%
Size: 4.0" Height, 7.5" Length, 10.8" Width
Features:
Available in 12V (CKMTA12) or 24V (CKMTA24) models.
Constructed primarily of light weight, high strength, engineering grade materials, including military and aerospace standard components.
Pressure switch controlled air manifold system regulates pressure between 9.3Bar [135PSI] and 10.3Bar [150PSI] suited to air tools and all ARB Air Locker equipped vehicles.
Highest air flow rate of any 12V compressor of its size on the market at 174LPM [6.16CFM].
High efficiency design consumes only 56 Amps at maximum air flow.
In addition to the compressors we also carry the ARB accessories including the hoses and attachments to fill tires:
Find them here.
As well as the rapid deflator style gauge that removes valve cores:
Find them here.
If you are looking for any other ARB product that you don't see on our website give us a call at 866 349 6801, or email us at [email protected].
