arb compressor
92xjkid
oregon
having trouble getting the arb compressor to kick on for my air lockers..
i flip the switch and noting happens? any ideas on trouble shooting?
Check all connections. Check any fuses. Check relay and replace if necessary...
There's always ARB Tech Dept as well. (425)264-1391 or (866) 293-9078
thanks for all the help ill try swaping out the relay.. and its been in the jeep for about 4 years so ill let you guys know what happens
Hopefully you called ARB, read the manual or have done some tests before replacing the relay. There are several tests that can be done to see if it is infact your relay before you replace it.
