BrettM
- michifornia
I'm pretty sure my truck will be ready to wheel tomorrow and I'm gonna head up to Fordyce on Saturday for a day run (early to late)
anyone want to come with?
BrettM said:you all missed out! it was great fun, I just got back I'll have pictures and info in the Mod Tech board later tonight
BrettM said:2 feet on the first one if you go to the left, then right to the top of my 35s on one of the other crossings
i'm too lazy to post pictures here, click the "my truck" link in my signature and go to the end of the thread
BrettM said:I didn't have the ARB hooked up because I'm not hooking it up with their switch and electronics, I'm doing it wholly pneumatic. I was still waiting on a pneumatic switch I ordered, which I got today. I am using a stock Sanden AC compressor for my OBA, with it regulated down to 90psi for the ARB. I put some of the pictures in the upload section of www.xjdb.com also
BrettM said:it's item MJTV3 from Clippard(.com), it's just a pneumatic toggle switch with 1/8" NPT ports.
I will make the Rubicon trip almost for sure, but I haven't planned that far ahead, so I'm not sure what day I'll go in, etc.
steinjeep said:Do you mean MjV3? I didn't see anything for mjtv3. How does that switch work. The arb wiring is a real pain. I have to still have to hook up to the ignition & illumination wiring. I hope I get it working for the Rubicon trip.
Troy
CRASH said:Why are you having so many problems with the ARB wiring? Didn't you buy the whole ARB harness? It has pre-terminated ends, and everything plugs in without any need for crimping or anything.
I think you are over-complicating the situation.
FWIW, I am also running the clippard switches.
CRASH
CRASH said:The switch is a mechanical switch that physically shunts air from the high pressure side to the low pressure side. When you turn it off, the air that is actuating the ARB is vented out the exhaust, and the high pressure side is capped.
there are no electronics.
ARB's harness is fairly bulletproof. Just like anything else, you must make proper electrical connections with solder and sealed with shrink wrap. Grounds need to be properly terminated to a sturdy, bare metal surface.
People have been running ARB components all over the world for about 15 years with very few problems. Like I said, it's all in the installation and execution.
CRASH
