Anyone using JUST Clayton's Crossmember for long arms??
Safari Ary
I'm pondering my own radius arm setup and feel that I have the necessary
skills to fab the arms and brackets and even the x-member. However,
Clayton's piece looks better than what I would end up building and for $250
it looks pretty appealing with it's drop out center section and all. Any
reason I should stop considering this as an option?? Any opinions on where
the arms mount to the x-member??
Here's a pic of the kit, sorry I couldn't find one of just the X-member:
corimgprv
Edit: it seems the pic doesn't work, and the page isn't linkable. If you wanna see the pic, go to www.claytonoffroad.com and look for the XJ kit.
Thanks
Ary
P.S. If anyone has better pics of the Clayton's crossmember, please share!
Thanks again
Another to consider is rustys the longarm kit they make uses the x-member as a mounting point and it has a one inch drop built in with no lose in clearnce the x-member by itself sells for a little over a hundred bucks.
Thanks for the info. I've seen the pics of Rusty's and honestly don't trust the bolt-on deisgn and don't need the drop(SYE). I've seen Clayton's piece up close before and like it, but am not whole heartedly attached to it if the wisdom of NAXJA points in another direction. Thanks
Ary
Matt from Florida did what you are talking about. I can't remember his last name or screen name (mattk maybe?) but he was the one in Tellico with the green xj with the 44 front and 60 rear. He trailered his XJ behind a camper if that rings any bells.
As for the x-member, I don't see how you could go wrong. The price is fair and you'd be hard pressed to match or surpass the craftsmanship. With his x-member most of the headache would be taken care of. Here's the only picture I have of it, you can get some idea of what it looks like installed.
If you need another picture let me know and I might be able to help.
the pockets to mount the arms are part of the crossmember. if you didn't want them there then it's not worth using his crossmember.
i think his stuff is top notch though. I can't say enough about his quality.
Wes and Bob, do you guys hit your X-members much?? Wes I think I've got a pretty good feel for where and how you wheel, and so your opinion definately helps. My biggest worry is that my radius arms will go straight to the center of the axle tubes, as opposed to below the axle tubes on Clayton's setup. I'm just worried that this might cause interference problems with the frame at only 5" of lift. I'm not doing your typical radius arm setup so don't yell at me for putting my mounts above centerline. Wait till I post my design before yelling at me:D THanks guys
Ary
I made my own crossmember simmilar to Claytons. I dont kwow what thickness he makes his out of but I used 1/8 to try and save weight. Out at Tellico I slid off the highside of a rock and droped almost a foot stright onto the crossmember and now there's a dent in it along with no paint left where it hit and the whole length of the belly skid from when I drove off of it. It was a hell of a hit seeing as it made me get out and check to make sure I didnt leave any pieces of my Jeep behind. The box tubing is slightly dented but still is stright and bolts right up to where it should go. If it was a factory crossmember I would have been stuck out there waiting on a replacement. Leson learned: Use 3/16" or 1/4" box tubing for crossmembers.
AARON
everything on clatyon's is 1/4" or thicker I believe. i've never gotten hung up on my crossmember that I can think off. certainly nothing that wouldn't have hung up even a stock cross member.
I did what you are thinking. I agree that it would be hard to do a better job on the cross member for less. Just as a piece of advice, use 3/8 wall tube on the arms. I bent my 1/4" arm on slickrock last weekend. With decent fab skills, better arms can be made for less. The only caveat is that you are trusting these arms with your life. If you are not a truly good welder, get one to do the job.
my .02
mattk
AARON
Lets see the pics!!!!
Thanks guys. I think I'm gonna take this idea and run with it. I'm in a metal fab/welding class right now. I'm not planning on building all of this till the end of the semester at the earliest, so I'll have my instructor supervise me and decide if I should do the welds or find someone to do them. I start learning Inventer(and CAD program) next week, so look for suspension designs in the near future.
Ary
P.S. Regardless of whether or not I make the arms and brackets, I will have someone install the crossmember professionally. I don't feel comfortable welding to the unibody myself.
I dont have any way of hosting them online and am too lazy to go find a free one. I can email you a photo of the crossmember but theres no skids on it seeing as I jsut got done tracking a tranny/transfercase leak.
originally posted by Ary'01XJ P.S. Regardless of whether or not I make the arms and brackets, I will have someone install the crossmember professionally. I don't feel comfortable welding to the unibody myself.[/QUOTE}
Welding to the Unibody is over rated. If you are in a welding class they should teach you to watch the weld puddle and the surounding metal for correct penatration and such. The same applies to the metal of the unibody. Just make sure you watch whats going on and you will have no problems. I welded my rockers on a long time ago and every wheeling trip I manage to smack them pretty good going somewhere a XJ with 32s open front and rear should go. My long arms have taken a beating at Tellico and they are still holding strong to the "sheet metal" underneath. That and I havent ever taken a welding class;) Death waiting to happen? Probally but we only live once.
AARON
Yeah send pics of the long arms too.Ill try and post them for you(if not maybe I can get Ary to help again)!!!
Ary,what about the loss of ground clearance.Thatsa good reason to look at fabbing some up!
Yes,the crossmember.I paid too much for lift to give it back!
I don't think the Clatyon's x-member hangs down any lower than my stock one, and I only hit my stock one back in the days of 225s and UC suspension. I admit that one of the biggest reasons I'm going LAs is for the street. I drive too much to put up with this ride much longer. The amount of work I'd put into a x-member wouldn't be worth it if I can get clayton's for 250, which his website says I can. Plus, if I use Claytons and it sits nearly flush with the bottom of my 231 then i can run a flat sheet of aluminum as a skid plate from the X-member back and down the rails. Won't have to make a hump for the 231 in the skid to get hung up on. If I start getting hung up on my T-case skid then I will lift more. I'm only running 4.5-5". So far I'm happy with my 33s and trim job. Just locked the rear-end, so as soon as I get the front end together I'll be locked front and rear, with long arms and 33s. Should take me everywhere I want to go. I'm really just waiting to hear from the guys who run Clayton's member to see if they get hung up on the rear LA mounts. Peace
Ary
