Hey,
Stuffs up for sale again:
Its all new stuff and never been turned over but was sitting outside so there is a little bit of surface rust on some parts but everything is perfectly useable after a good cleaning as there is no pitting. The block is stamped 1992
I have:
-Block which could use to be hot tanked and have the bore's honed, other than that its perfect.
-Oil Pan
-All rods and pistons, need new bearings and rings
-Crank, journals need to be have rust polished off but there is no pitting so it does'nt have to be ground at all
-Camshaft, perfect shape, no rust at all
-Lifts, pushrods, Timing gears, chain and Cover
-Main caps and bearing caps
-oil pump
-6 injectors that came out of my '91, they have about 160k on them but worked perfect
-an old exhaust manifold from my old '88, the flange broke off but i have it welded back on and as far as i know it does'nt leak at all.
i think thats about all i got laying around, possibly could have a set of Canyon's up for sale in a few weeks in excellent shape.
Thanx for looking
Eric
I have:
-Oil Pan
-oil pump
Thanx for looking
Eric
