- Southern Maryland
The alternator being under the jeep and the AC compressor being on top seems totally bass-ackwards to me. For one thing the AC does not have to be used, but the alternator MUST BE USED, so it makes sense that the alternator would be on top away from the mud and water, while the AC compressor was down low (and it can be shut off if it's at risk).
Also they are pretty well stacked on top of each other and all the lines and fittings are pretty much right next to each other so... should be feasible. Biggest problem is that some brackets would have to be fabbed up to make the swap.
Anybody actually done it?
