CheapJerokee
- CA
I will provide cold beer/alcohol of your choice, food and gas money
I'm new to Jeeps and would appreciate some help and expertise. I just bought a 1997 Cherokee RWD (with previous owner installed other Aisin trans and a 231 J transfer case). I have done some drain and fills. I've replaced the fluid in the axle and keep changing the engine oil. There is definitely gas in the oil. I started off with 7 diagnostic trouble codes and I am down to 1. The Jeep is running extraordinarily rich although I think it has gotten slightly better. My mileage went from 8 to 10 mpg. I've already replaced, plugs, plug wires, coil, o2 sensors, oil sending unit, and a few other things. Does anyone know a good place to get new window
I will be replacing:
- water pump
- lower radiator hose
- harmonic balancer
- Thermostat
- water temperature sensor
- clutch fan
- belt
- power steering hoses
- oil pan gasket
- engine oil pump
- rear main seal
I was wondering if anyone would like to help me finish installing these. The more the merrier. I am located in Hemet - which is about an hour from Riverside, an hour and 10 min. from Fallbrook, and about 40 min. from Temecula.
- water pump
- harmonic balancer
- Thermostat
- clutch fan
- belt
- oil pan gasket
- engine oil pump
- rear main seal
