wizardPC
- Nolensville, TN
For the 97+ models, I designed a 6 switch panel to replace the oem one:
Since I have the model for the switch port anyway, is there any interest in a panel for the earlier XJs? I'm pretty sure I'd be able to squeeze three XJ/TJ OEM switches in the panels to the left and right of the steering column.
I'd need someone in the Nashville/Franklin/Smyrna area with an older XJ to help me test fitment.
The major problem, of course, is that those XJ/TJ switches are like $18+ each, and the early XJ/YJ switches can be replaced with $2 contura knockoffs.
