First off, 1996 Cherokee sport 4.0, auto trans, and I tried to search for this. Here's the short story: So I was using my right turn signal a few days ago and all of a sudden my column starts smoking from where the tilt lever is. A fuse or something blew, and the turn signals stopped working completely, along with my dash lights, and about half of the fuses in my fuse panel under the dash. The wiring harness that goes to my ignition switch has a couple of wires that are pretty charred where they leave the connector to the switch, so I figured this was the problem. Tried to replace it, no changes, and now a couple of the mini fuses under the hood don't have power to them at all. One of them being the auto trans wiring fuse, which leads to the trans basically not working. I keep reading that there are fusible links somewhere under the hood but I have no clue where, and in the owners manual it says that they replaced all of the fusible links with maxi fuses under the hood sometime in the mid 90s. If that is the case, all of mine are in good condition but I still can't figure out where the break in the power is. Anybody got a clue on where to go from here? I've dug into quite a bit and don't seem to be getting anywhere. Hopefully somebody else has ran across this and knows what is going on. Thanks in advance for any help.
