rogerramjet
- Pennsylvania
My wife and I are being moved from PA to TX by Uncle Sam and the USAF. Unfortunately, they do not move vehicles. The plan was to each drive our vehicles, but I was wondering about the possibility of either trailering hers or putting it on a tow dolly.
Hers: 1999 BMW 323i GVW - 4211 lbs.
Mine: 1997 XJ, GVW - 4601 lbs, with 3 inch lift, 31's, stock gears, bastard spring packs from 1/2 ton Dodge pick-up, rear disc brake conversion from '95 ZJ on Dana 35's.
I've searched enough to know that long distance towing with an XJ is generally not recommended, but I was hoping for a "maybe if you...." advice.
Thanks-
Mark
Thanks-
Mark
