Hey, done lots of reading and searching, time for a humans touch. I installed an RE 4.5" lift new stuff. With bar pin eliminators,1" minus on the shocks.(though I did 4.5" rear springs and I talked to RE today and they said they do 3.5" spring and 1" shackle) the rear rides high and I may have to shim for pinion angle, ads 1/2". So my ? Is what part # bilstein a do I run? they have a shock for 4" of lift and a shock for 5-6" lift. The 4" is cutting it close but the other seems close for being to long.
Front 24-188197 and rear 33-066868 is 4" of lift
Front 24-185943 and rear 33-151663 is 5-6"
My shocks and my discos are off and I jacked up each end to get a measurement for the shock length, and the new stuff don't flex for shit.
Just sitting I got 20" in the front and 21" in the rear.(with BPE's)
Front flexed at max is 17" and 21 1/2"
Rear was 19 1/2" and 22.5"
These numbers are of course in the garage, real world adds more inches,sooooo
My question is what are you guys with 4.5" of lift and 5100s running? What part numbers?
2000,4.5",auto,d44 HPd30 f&r lockers lotsa goodies
