Yamadevil
- Apple Valley, CA
Ok I went to smog my XJ for the first time and HAHA gross polluter. So now i paid for a fail and he told me it needed a cat so i had a cat put on. Now for you smog guru's here are the numbers can you please tell me if it sounds right or will i drive in to give away more money to the smog man with another fail. Keep in mind these numbers are before the new cat, I have not been back after the install. 90 XJ 4.0
15mph co2 14.40 02 0.68 HC max 123 measured 81 CO% max .73 measured .18 NO(ppm) max 711 measured 1905 this was the gross polluter number
25mph co2 14.28 02 .65 HC max 103 measured 73 CO% max .93 measured .33 NO(PPM) max 613 measured 1436 this was a fail
So the NO was the failing number at both speeds which i think is nox this guy also said the 02 reading wasnt right or something
Any help or advice would be appreciated. Thank you in advance
