greenchevy
- Joshua Tree
Ok so I hate Cali smog. Just had to rant for a second. I've never had this much of a problem smog-ing any of my vehicles or this jeep before. these are my results from the first fail.
1989 Jeep Wagoneer Limited 4.0 inline 6
Hc(PPM) readings
Max GP Meas
Idle-580 120 270 355
2500 RPM-2657 180 330 97
CO(%) readings
Idle-580 1.00 2.50 .23
2500 RPM-2657 1.00 2.50 2.89
fixed misfire, did tune up, replaced catalytic converter and 02 sensor.replaced injectors still failed CO% and HC(PPM). Results from second fail.
co(%)
Test RPM MAX GP MEAS
IDLE 620 1.00 2.50 6.36
2500 RPM 2370 1.00 2.50 9.54
hc(ppm)
IDLE 620 120 330 203
2500 RPM 2370 180 270 153
My CO% is 6 times the max limit at idle and over 9 times the max limit at 2300 why is this so high with a new cat, tune up, 02 sensor, injectors?
Hc(PPM) readings
Max GP Meas
CO(%) readings
co(%)
hc(ppm)
