ChiliRed98
- Hernando FL
Hey all quick question.
I just picked up a set of TJ canyons with 30x9.5x15 Dayton Timberline AT on them and all is well so far....no rub or anything. I want to give the jeep a bit more lift now that I have them on.
I currently have a set Quadratec/Crowne HD spring in the rear and stock up front. I Measure 17 3/4" up front and 18" in the rear. The guy I got my wheels has a TJ and has 1 7/8" coil spacers which I'll be picking up for $20. (Am I correct in assuming the fronts will fit the front?)
My whole question is about the back...I have my old set of warn out leafs laying around...should I bastard pack them into the HD pack for 2" ....is it worth it and which to add for only 2" ...I read a majority of people get 3"-4" out of them. .
OR
Should I just pick up a set of rear 1.5" - 2" shackles and call it a day since I have newer "stronger" HD springs which may make them less prone to sagging?
Spark notes: Bastard pack HD spring for 2in or just buy 2in shackles.
Thanks in advance! :wave1:
The Jeep in question with the TJ canyons.
OR
