chrslefty
- centeral phx az
hey guys i need some help if you would be so kind ?
i did my lift and I'm at 6" in the back and i need to get my angles straight/right.
heres where I'm at right now :
at the t-case i have 5 deg and the d-shaft is 17 deg
at the axle i have 12.5 deg and the d-shaft is 17deg
i don't have my sye on yet and so I'm still running the stock shaft and slip yoke.any ways its binding while turning and vibrating at low speeds so i would like to get it fixed .
so what shim do i need i think that its 6 deg ,or do i need to lower the t-case and shim or just shim ?
thanks for your help .
chris
chris
