J JEEParon NAXJA Forum User Location Sandy, OR (PDX) May 10, 2005 #1 will an AMC 360 bolt directly onto an AW4??? or would i need to get an adapter
Eagle Lifetime NAXJA Member NAXJA Member Location Terra Firma May 10, 2005 #2 I know for a fact that an AX-15 will bolt directly to an AMC 390, which uses the same basic block as the 360. That would suggest that an AW4 will also bolt up -- but you have to find a flex plate to work with it.
ROBZ95Xj NAXJA Forum User Location Keene NH May 10, 2005 #3 This guys bolting up a 401 wich is externally identical to the 360 http://www.naxja.org/forum/showthread.php?t=53767&highlight=360
