Mike L
- Anaheim, CA
Last week I was having an issue with the alternator and battery cables in my 98 Cherokee with the 4.0L. The original 90 amp alternator and cables had over 214k on them.
The alternator was not charging the battery and it was running off the battery alone. Long story short I had it towed and started tearing it apart.
I pulled the alternator and had it bench tested at two different AutoZones and both places showed it was putting out over 14 volts.
The battery is a 10 month old Optima Red Top.
I figured it was time to replace my battery cables as they looked pretty bad and the alternator tested good:
The battery + to starter is now 00AWG
The battery - to the block is now 00AWG
The rest are now 4AWG: battery - to chassis, battery + to PDC, alternator output to PDC, and block to chassis
The upgraded 4AWG charging cable is connected to the PDC with an inline Mega Fuse, similar to CharlesS setup:
http://www.naxja.org/forum/showpost.php?p=245429748&postcount=2
After getting everything back together I was getting 13.5 volts with the engine running and I thought everything was back to normal.
On my way home from work yesterday the voltage gauge on the dash was reading 12.5 and after a few minutes the voltage gauge dropped out to 9V. I understand the gauge dropping the 9V is normal in the 97 and up when it is reading low voltage for a prolonged amount of time.
When I got home I checked the voltage with the engine off and got @ 12.5V, with the engine running I was getting the same 12.5V. I removed the connector at the back of the alternator and cleaned the connectors and reinstalled it. I then rechecked the voltage: engine off was 12.5V and with the engine running I was getting 13.36V. I checked the voltage at the battery, PDC terminal, and the B+ terminal on the alternator and was getting the same 13.36V. I drove it around a couple times last night and it was giving me the same voltage readings so I figured it was okay.
Fast forward to the commute to work this morning and the dash voltage gauge was reading 12.5V again and a few minutes later the gauge would drop out.
I understand the PCM is what regulates the alternator. What are some other possible issues? The battery temp sensor is under the battery and I am not getting any codes.
