4WDlifeform
- Beaver Falls, PA
Hey guys. Got a question or two about air dryers...
Here is what I am looking at getting:
This is a mini air FILTER. but it has water run off, so im assuming it dries the air too? but, there is no pressure rating on this (yay harbor freight!), or others like it, so, does it go on the intake side of the compressor?
Also, what about the chemical ones, (they turn blue?) those worth getting? I don't want to have to keep taking apart my air system though to change the dryer.
What im doing: This is for my on-board air system. I have an electric compressor, pumping into a 5 gal tank. Im running as high as 135psi when necessary. Im most concerned with water accumulating in the tank causing rust. Draining the tank is a pain, and I think I realize that even with a dryer, its not going to be perfect but I'm thinking it'll help? I use it for the tires, and train horn mostly. Some small air tools on occasion. Let me know what you guys think. I'm open to new ideas too, as I'm going to be ripping most of this apart this week.
Thanks!
Thanks!
