After all the mods...
Royce
Pa
I lifted, got aftermarket LCA's and an Adjustable Trackbar, now I need an alignment. Anything I should be looking for. I don't want to be hosed on this. I just need the front end right? Is the 4 Wheel alignment thing just BS and a quick buck or what. Clarification is need. Thanks guys.
You need your caster and toe checked/set. Caster is set with your LCA's and toe with the tierod. A good alignment shop should be able to adjust your trackbar if needed. Or you can do it your self. Just get the axle centered under the jeep.
