Bbasso
- South Carolina
Hey all,
after going to a few wheel alignment places, the drivers side camber is off with no adjustments to correct it.
Thoughts?:idea:
Then the noise from the front axle... sounds like wheel bearings. And the slightest popping when full lock turns at slow speeds.
One mechanic thought if the bearing(s) are toasted enough it could cause the camber issue.
Thoughts?:idea:
So if you owned this XJ, what would do? :looney:
Thoughts?:idea:
Thoughts?:idea:
