jimmydaux
- Centerville, Utah
Has anyone tried to add a switch to control the doorlocks from the back hatch? Suburbans and tahoes have them in some years, and it seems like it would be nice to have. If youre locking up but have to get something out of the back, you either have to power lock everything, then unlock the hatch, then lock the hatch, or get whatever you need from the back and go back up to lock the rig up with the power lock button. It would be so convenient to be able to lock/unlock the rest of the door from just inside the rear hatch. Would I have to run the wires all the way up to the door switches to make it work, or could I tap into the system at the rear hatch actuator? I know that when Ive installed keyless entry systems in the past, some locks use a negative (-) feed rather than a (+) positive feed to trigger the mechanism. If theres any of you door lock/electronics gurus out there, I wouldnt mind your input.
