actual size of 35x12.50x15 BFG M/T
jsjeep98
does anyone know the actual dimensions of a 35x12.50x15 BFG Mud Terrain tire that has been mounted on a 15x10 wheel. with just normal air pressure?
wondering if anyone knew if the diamater was less than or greater than 35"
thanks everyone
does that .6 of an inch matter anyway?, i mean, your jeep will only sit .3 of an inch taller. and a wheel width would not change the overall height by a significant even measurable amount anyway.
yeah your right. i was concerned earlier when i had just cut the fenders and it measured about 36in. and was wondering if i could still fit a 35" tire in there. then i found out more what bumpstops to use and all that. but i may need to bend a bit more back.
