Acid/Metal Etching Solutions
millhousenator
Ohio
Im looking for a cheaper alternative to POR15's metal etch. I have heard you can buy such products at hardware stores, but quick searches online dont give me any results. What is a good brand that I can buy locally at the hardware store?
After checking the msds for metal ready, it seems that most of it is phosphoric acid. the stuff that makes up naval jelly and what they put in cola.
Its also has zinc phosphate which is the "residue" which i guess is like parkerization.
As far as options, naval jelly, but it seems that por-15 is kind of a one of a kind recipe
Hopes this helps
Check out a company called Top Secret Coatings. Their stuff is as good or better than POR-15 and is UV protected.
I already have chassis saver on order from magnet paints. This TSC Rust converter Cleaner looks promising to prep for the chassis saver and bedliner though.
