Accesories Part Out...everything must go!
HQuakers
South Jersey
So if you read my thread you'll know I totaled my Cherokee. I removed all the extra stuff I put on and although I wanted another Cherokee, I couldn't find one in good enough shape that I liked, so I went back to a car.
So, now I have all my stuff I need to get rid of as I have no use for it.
First up are 4 31"x10.5" BFG M/T with about 15k miles on them. I labeled them how they were on the Jeep because I was planning on rotating them the weekend I crashed, so you should put them on in the opposite order they are labeled. I only had the meterstick to measure the depth, but I don't know how accurate that is. Figure anywhere from 3/8"-1/2" depending on the tire.
These are mounted on some 15" American racing wheels with centercaps.
Price: $400. Local Pick Up Only.
Next is a Pro Comp M/T Spare, same size as the BFG M/Ts. This tire is mounted on the same wheel as the others as well, though it's in almost new condition
since it wasn't used. This tire does have a plug in it but it was like that when I got it and holds air perfectly. Tire even has the little nubbies still on it. Comes with a nylon cover.
Price: $100. Will not ship but I can meet up with someone in the Philadelphia/Trenton area if you want.
Next is an Or-Fab 83203 Front Winch Bumper in Textured Black. This is a beefy unit, which ties into several points in addition to the stock bumper mount. All holes and bolts/nuts are labeled as best as I could. I will include 3 new steering box bolts as well (left mine on Jeep). The one side is bent (see pictures) as that hit the tree. I can try to bend it back, but I really don't know how since it's very thick steel. You will need to bend it in order for all mounting holes on that side to connect to the center section. There are a couple rusty spots underneath some of the welds where the powdercoating didn't quite reach.
Since it's bent I'm looking for $200 for it. I paid $570 at Quadratec back in October and didn't even winch or pull with it. Local Pick Up Only.
To go along with the bumper, I'm selling the light mount for the bumper. Has 5 holes in the top to mount lights, and bolts on in about 5 minutes. In perfect condition.
Price: $20.
Lights:
PIAA 510 fogs with wiring kit (plug and play). Comes with box, instructions, plastic see-through covers, and light locks. They are amber in color.
Price: $100.
PIAA 520 ATP 6" with wiring kit (plug and play). Comes with box, instructions, and plastic see-through covers. They are an ice blue color.
Price: $100.
(mounted on the rack still...will take them off)
Hella 700FF 7" with heavy duty wiring kit. I made up a kit from another Hella heavy duty harness. The bulbs in there are 100W Hellas but they will come with the stock 55W as well. Comes with box, instructions, and plastic covers.
Price: $50.
Uniden PC78 Elite CB. I barely used this...only took it with me when I went off road. See the specs here: http://www.uniden.com/products/productdetail.cfm?product=PC78ELITE . Comes with mounting kit and a new wiring kit and box. Comes with a PA speaker that is PLENTY loud, and fun too ;)
Price: $100.
Roof Rack. Bought this from a fellow member. VERY sturdy unit. Floor is welded to bottom frame. Has some universal 55W H3 lights mounted on the back. Comes with two self-rolling ratchet straps. These are perfect for holding a spare onto the rack, and are great because the excess strap rolls into the unit so no flapping in the wind. I also built a wind deflector (with light cutouts) out of 1/4" ABS plastic. Good for 1mpg ;) Some paint flakes on the rack so it will need touching up. Uses SURCO mounts to mount to the drip rail above the doors. Mounts are in perfect shape. This rack is very sturdy. I walked on it, hung from it, carried spares...never missed a beat.
Price: $200. Local Pick Up Only.
Mean Green Battery tie down. Comes with good J-Hooks that attach perfectly to the stock battery tray. Good shape.
Price: $10.
Rear cargo mat. Little dirty but I will wipe it off before you buy.
Price: $20. Prefer not to ship these but I can meet up with someone in the Philadelphia/Trenton area if you want.
Front/rear floormats. I bought these online and they are NOT OEM, so they don't fit perfectly. Driver's mat has eyelet for hook. There are the nubbie things on the back to prevent slipping. Not as thick as OEM mats, but still work VERY well. Rear mat is a one-piece over-the-hump style. Color is Agate.
Price: $30. Prefer not to ship these but I can meet up with someone in the Philadelphia/Trenton area if you want.
Front/rear all-weather floormats. Front mats are from mats4less.com and are VERY heavy duty. Worked fantastic in the snow and mud. Front have nubbies on the back to prevent slipping. The rear mats are just universal square mats. Served their purpose.
Stock Fog Light Switch. Perfect condition.
Price: $20.
Stock Infinity tweeters.
Price: $20.
Reese 20' Tow Strap. Brand new. 3,330lb strength, 10,000lb breaking strength.
Price: $10.
Barri-Nut Light Locks. 10x1.25 thread pitch. Brand new. Did not fit any of the PIAAs or the Hellas, so I'm not sure what lights they do fit.
Price: $10.
2" Hitch D-Ring mount with 3/4" D-Ring. Made from solid aluminum and weighs quite a bit. Never used it to pull anything but did have it in the hitch a couple times.
Price: $25.
Fire extinguisher with mount. Needs to be recharged. Dry chem.
Price: $10.
To see all the pictures in an album, go here: http://smg.photobucket.com/albums/v244/HQuakers/Jeep/100105_ForSale
Help me get this stuff out of my garage. I tried to price the items reasonably so I can get them out of here, but please let me know if I'm way off on anything. I didn't put the prices I paid for anything (except bumper), but most of the stuff is 30-50% off what I paid. Everything has less than 6 months on it...some have a couple weeks, others the whole (almost) 6 months.
Items are located in Shamong, NJ right on the edge of Wharton State Forest.
Prices don't include shipping, but you may be able to twist my arm to include it ;). I also accept PayPal.
Thank you.
Sent you a PM about the Tweeters. next in line for them.
i'm very interested in the fog lights at least one set in less u want to work something for two of them
the ones i want are the hella's and the 520 piaa's let me know
shiping would to 18512
let me know
thanks,
-Dylan
PS - sorry to hear about your Jeep. This must be a little tough on you parting her out.. :-(
put me in line for the tweeter and fog light switch, let me know on shipping to 40517, thanks, and soory to hear about your XJ, i think i would cry
wish i knew all this was up for sale when I was down there to get the jeep. I had 1k extra in my pocket
Sorry about that. Someone was going to buy it all to swap over but he backed out so I'm kinda grabbing at straws here..I can work something out if you want anything.
Hey -
I'm a friend of Roy's. He let me know about your posting, sorry to hear about your jeep. I'm VERY interested in the roof rack & bumper. Would you sell both for $350 and possibly throw in the set of Hellas?
Roy said he was going to give me your number so I could call you tomorrow, but it seems you are checking this regularly.
I'd be interested in the battery holddown and the cargo mat, for sure, maybe the other floormats as well, and can pick up at your leisure. Call me at 856-373-8767 if you want to catch up and unload them, I can pick up.
Thanks, Rich
Hey -
PM sent with my #
Thanks, Rich
PM sent with my #
4 BFG wheels/tires and Floormats are sold.
Sale pending on:
Battery Hold Down
Cargo Mat
Roof Rack
Bumper
Hellas
Tweeters
Fog Light Switch
PIAA 520 ATP
Make offers for the PIAA 510s, Spare, tow strap, fire extinguisher, and CB!
