VAhasnoWAVES
- Lake City, Mi
on a recent wheeling trip, a bad Ujoint made me put a buddies spare shaft into my '97 XJ (which has 297s stock). the shaft was from an ABS equipped XJ of an unknown year, with 297s installed. the length of the stub shaft and inner shaft appeared to be the same, and have been working properly ever since, but i instantly noticed a couple differences in the two shafts.
*** the diameter of the shaft itself was noticably bigger, then necked down at the seal area.
*** the ears on the ABS shaft were CONSIDERABLY bigger, and beefier looking.
stock shaft in my '97 cherokee, with 297 joints:
ABS shaft from unknown year with 297s:
thinking outloud here...
im not saying it cant happen, but most shaft failures ive seen on stock shafts are at the ears, not the shaft itself. this usually leads to or was caused by Ujoint failure, and can lead to BJ failure. these ABS shafts appear to be an upgrade to me. the are much bigger and beefier all around. am i wrong? why have i not found ANY info on this? i feel like someone would have noticed this a long time ago.
