Mc2KXJ
- Union of NAXJA Socialist Republics
I just did an axle swap and no longer have ABS in the rear. I am trying to delete ABS from the front now and need help with what to remove. I was looking online and found 1 fuse position to kill the ABS light and then found this below for the ABS controller. My concern is removing it considering all the other devices that use it. Any thoughts?
Fuse #25 shift lock solenoid, a/c heater control, abs controller, abs controller relay, blower motor relay, blend door actuator
Thanks,
Rich
Thanks,
Rich
