dcXJ
- Richmond, Virginia
I want to put in an AAL and currently I have the rear OME HD full spring packs. I've heard two different stories...one is that the OME packs do better with the OME add a leaf only...and the other is that an add a leaf is an add a leaf, and I can go a cheaper route and get a different brand (like RE, or Skyjacker, etc....), and be fine.
I wanted to know what some of you thought. I'm going up to 4.5" in the front and want to bring up the rear to match depending on how much lower it sits in the rear after the 4.5" springs are put in up front (right now the rear is at 4" above stock, and the front is at 3.5" above stock. I'm getting the 4.5" coils put in because I'm running the OME 930 coils and a spacer, and want to get rid of the spacer and use a full coil), so I'd just like to hear some opinions on what you guys think of this.
Thanks
Dave.
Thanks
Dave.
