Non-StopXJ
- Kansas
I've read multiple threads on the prepping, and install of many different products (Herc, Raptor, Duplicolor, Rhino, Monstaliner, etc.) and none of them explained in detail what they did with the floor pan drain plugs/holes.
I going with a roll on application of Monstaliner to avoid over-spray issues, and I plan to replace the factory carpet so it doesn't have to have a show-room finish.
1. Do I pull the floor pan plugs, apply the liner, and then replace the drain plugs after the cure time...or just leave them in and apply the liner over them?
2. How long to wait (after the 48-hour cure up) before totally replacing the full interior?
3. Has anyone used, or heard of friends using Monstaliner on their XJ interior?
Monstaliner do-it-yourself roll-on truck bed liner outperforms Herculiner Bed Liner, Duplicolor and Rustoleum Road Warrior
Any tips, help, and comments are welcome because I want to have the gameplan set before I mix up the liner and get to it.
This stuff has less than a 24 hour pot time on it which doesn't leave a lot of time for second guessing.
