A few Items for sale
xjjeepthing
Plymouth Indiana
I have 3 brand new K&N Air filters still wrapped in the plastic and in boxes.
First $20.00 plus Shipping
33-2819 Product Specifications
Product Style: Panel Air Filter
Height: 1.063 in (27 mm)
Outside Length: 10.375 in (264 mm)
Outside Width: 5.625 in (143 mm)
Filter Re-Oiling Amount: 0.86 oz (25 ml)
Weight: 0.8 lb (0.3 kg)
Product Box Length: 13.5 in (343 mm)
Product Box Width: 7.75 in (197 mm)
Product Box Height: 1.75 in (44 mm)
Fits 1999 to 2004 Ford Focus
http://www.knfilters.com/search/product.aspx?Prod=33-2819
Second $25.00 plus Shipping
E-0945 Product Specifications
Product Style: Tapered Conical Air Filter
Base Inside Diameter: 4.438 in (113 mm)
Base Outside Diameter: 8 in (203 mm)
Height: 8 in (203 mm)
Inner Wire: No
Top Outside Diameter: 3.875 in (98 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 1.42 oz (42 ml)
Weight: 1.4 lb (0.6 kg)
Product Box Length: 8.25 in (210 mm)
Product Box Width: 8.13 in (206 mm)
Product Box Height: 8.75 in (222 mm)
http://www.knfilters.com/search/product.aspx?Prod=E-0945
Third $25.00 plus Shipping
Inner Wire: No
Top Style: Rubber
Also have a ring and pinion from a 1996 Grand Cherokee 3.73 ratio from a dana 30
Make offer plus shipping.
Which dana 30 axle do these come from, are they from a CV axle shaft or the standard u joint axle? How many miles do you guess are on them. Thanx Digger
I believe CV type and about 80,000
