asp
- Westport, MA
I've never taken apart a disconnect D30, but I essentially know how it works. I also am currently running a geared and locked D30 with the disconnect bypass already installed (297 shafts with the seal pressed in, etc). I would like to keep this housing simply because it's already geared and locked, but i know that the best thing would be to get a new HP housing... My question is that if i uninstall the little housing thing on the back of the axle tube that the disconnect is in, can i form some plate and weld it in in place of the disconnect box and parts? I want to truss it, but that little extra box bugs me. Is there any reason i can't just take it off, weld on some plate, and put a seal right outside of the carrier, like the non-disco 30s?
