scguy27
- Barnwell, SC
I've got an 89 Comanche that I have HO swapped with the complete drivetrain, harness, heater box, dash, etc from a 93 XJ.
The parts XJ I used had a AC compressor installed that isn't correct, it's too long for the mounting bracket. The front two bolts line up, but the rear bolt holes hang off the back of the bracket. I believe it has a 94 compressor. No AC lines were present. I'd like to get the proper setup, what are the year breakdowns for different setups. It seems like 94-96 is one segment, what years can I use for proper 93 parts? I'll need the compressor and all the lines. Will my 89 condenser still work?
Thanks
Thanks
