hoagiexj
- Chesapeake
A few days ago, A/C stopped blowing cold air. Tried adding freon. Thats all good. Was about to change out my compressor when I thought about checking fuses and relays. Relays under hood were all good. Checked fuses by passenger side floor. My manual says slot 10 empty. After doing some searchs on . Found out that slot 10 controls your compressor!!! Sure enough...blown fuse. Just thought I'd put this out there for you's guys having the same problems in this heat.
Hoagie
Hoagie
